Hi all!
I’ve just drop an eac3 7.1 file on last Audacity version.
These info are from MediaInfo:
Audio
Format : E-AC-3
Format/Info : Enhanced AC-3
Commercial name : Dolby Digital Plus
Format profile : Blu-ray Disc
Duration : 2 h 31 min
Bit rate mode : Constant
Bit rate : 896 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 973 MiB (100%)
Service kind : Complete Main
Dialog Normalization : -28 dB
compr : -0.28 dB
cmixlev : -3.0 dB
surmixlev : -6 dB
dmixmod : Lo/Ro
ltrtcmixlev : -3.0 dB
ltrtsurmixlev : -4.5 dB
lorocmixlev : -3.0 dB
lorosurmixlev : -4.5 dB
dialnorm_Average : -28 dB
dialnorm_Minimum : -28 dB
dialnorm_Maximum : -28 dB
Now I see correctly 8 clips on Audacity.
Which channels are they?
I mean, track 1 → L, track 2 → R, ecc
Where I can find info about DD+ 7.1 to solve my problem?
Thanks
