Does Parametric EQ exist for Audacity users?
I’ve spent DAYS trying to find this plug in for Audacity but is it really just an apparation, a hoax?
Can anyone point me to a location where I can successfully - the keyword successfully - download and activate this elusive ghost-like plugin and ACTUALLY use it in Audacity v2.3.3?
Love Audacity.
Don’t love obscurity.
Try [u]this one[/u] or Google “VST parametric equalizer”. (Audacity supports VST plug-ins, although not all VST plug-ins support VST.)
Audacity’s built-in spectral editor has a parametric option …
https ://manual.audacityteam.org/man/spectral_selection.html#eq
THANKS FOR THE LINK
I’ll try that DVD Doug.
Oddly enough I have 2.3.0 on my PC at work which lists the parametirc in Effects
But 2.3.3. installation on another PC doesn’t
I don’t recall loading a plugin on 2.3.0 though
Puzzling
I know nothing about audio but need to edit some audio in video clips - remove room echo from voices
Just to say a big thank you to you guys for your help Im still looking at a lot that seemed to pop up with the links you suggested again many thanks Katie
