Note that the first unselected track underneath the selected track(s) acts as the control track.
This looks like a lot of steps, but some may not be necessary, and it’s much quicker to do than to type out
Get all of your audio clips imported first. They may be in multiple tracks.
Move the “music track” (the one whose volume you want to modify) to the top. This is most easily done from “the track’s drop-down menu > Move track to top”.
Select all (“Ctrl + A”)
Move focus to the top track (“Up cursor” until the top track has the yellow border).
Press “Enter” to toggle the selection of the first track so that it is NOT selected.
“Tracks menu > Mix > Mix and Render to New Track”. This will create a new “Mix” track at the bottom of the project.
Move the mix track to the top of the project.
What makes you say that? The OP includes a video that clearly shows that they are using Audacity and not “a video editing software”.
That’s not a solution. Audacity is perfectly capable of applying AutoDuck. Having to learn how to use an expensive alternative to Audacity does not solve the problem, it just shifts the problem onto other software.
Surely “Audacity” is dedicated audio processing software.
“multiband compression” is not “auto duck”, they are completely different effects. Yes you can use a compressor with side-chain to perform auto-duck, but that’s a different thing to “multiband compression”.
