Does Audacity have a Codec to convert Dolby AC3 files
I need to be able to convert old Dolby AC3 files over to mp3… Is there a Codec, or Plug In that will let Audacity do this… I have versions 1.2.6 , up to the current version of Audacity, and older Windows PC’s up to modern PC’s, so I should be able to run it if it is out there… Thank you for any help with this subject… - Andy
Audacity doesn’t have codecs to convert anything, but you can install the FFMpeg software and get all of its codecs.
http://manual.audacityteam.org/index.php?title=FAQ:Installation_and_Plug-Ins#installffmpeg
It is suggested that if you need no editing, filtering or effects, that you do straight conversions outside of Audacity. Audacity is not a WAV editor and has to do internal conversions to get sound in and out. Each conversion contributes slight distortion.
