Hi,
Can someone please let me know if I can use Audacity 2.3.3 on Windows to smooth a small section of a track (see screenshot below)?
Thanks & regards,
Lee
Hi,
Thanks & regards,
Lee
Even if you went to the effort of making the upper-envelope ruler-straight, it would make little difference to the sound.
Thanks for your response and heads-up.
Regards,
Lee
Dynamic range compression could make the envelope straighter, but more horizontal rather than sloped.
(Then you could add back the slope with the envelope tool).
But I doubt you’ll be able to hear any difference by straightening-out the slight undulations the envelope.
Thanks for the information. I played with parameters in Effect → Compressor but didn’t see it makes envelope straighter ![]()
It already looks fairly smooth. What’s the purpose? (What are you trying to achieve, and why?)
