I am wondering if I have the full version of audacity. I tried to edit a peace of music (taking out the intro) and following along in a simple Youtube tutorial makes it seem easy. Go to where you want to edit, drag the cursor to what you want to cut, go to the menu bar and click on edit and cursor down to delete. My problem is that under my edit tab there is no delete.
So, any input on how to figure out what version of audacity I have would be greatly appreciated.
Using the menu system is good for learning, but you should advance quickly to keyboard shortcuts. Someone even moderately good with the keys can edit a show and be on the way out for a coffee/tea while you’re still trying to find all the menus.
Help > About? I’m not sure where it in on Windows machines.
The current version is 2.0.5.
If you have any doubt, you can get it again from our supply. It should reinstall without losing any of your preferences.
Irrespective of where Delete is, the real answer is to use the current version of Audacity ( http://audacityteam.org/download/ ) then read the Audacity Manual. The Manual for the current release (whichever version is current) is here: http://manual.audacityteam.org/o/ .
The trouble with looking at YouTube videos is that even if they are factually accurate, they rarely say what version of Audacity they relate to, and you may have a different version.
