Dividing one long audio recording into smaller segments?
Hello, I am recording from cassette tapes and once the entire tape is done I have one long track! How do I divide it to the individual tracks so that when I burn a CD I can select the song I want? Thanks so much for your help.
The best demonstration of what you are asking about is in this YouTube video: Dividing audio into tracks.
Here is a sample workflow from the Audacity docs: https://manual.audacityteam.org/man/sample_workflow_for_tape_digitization.html
I hope they both help.
Hello and Thank you! The workflow doc was exactly the instructions I needed. I have burned a CD using that and it worked great!
Thanks again,
Chuck
Blimey,
You don’t hang about do you? You did it already.
I am really pleased the info’ helped you accomplish that. There will be no stopping you now. :grinning_face:
Small things - Huge benefit!! I record a Zoom Open Mic session every week and then the next day break 3 long tracks into about 20 individual performances. Using labels instead of creating new tracks to cut and paste? Dramatic savings of mindless tasks!! Thank You!!!
