Distortion and bad sound when recording vocals
I updated to the Audacity 3.7.4 version on July 3rd. All these years I’ve used Audacity I haven’t had the issue of recording my vocals and the outcome being in and out distortion and when holding a note, it doesn’t record at all. Also the sound is muffled. I also used 2 different mics and it’s the same outcome. Anything I can do? Would greatly appreciate a fix - Thanks, Geno
These are the symptoms of audio enhancementhttps://support.microsoft.com/en-gb/topic/disable-audio-enhancements
