Distorted Playback of Audacity Recording
Hello!
I recorded material yesterday, very routine. The acoustics were clear.
When I played it back, it is heavily distorted.
Nothing has changed on the settings.
I noticed the levels were pinned on the playback. That’s unusual. I don’t overdrive the inputs. I expect it is the distortion.
I’m using Firefox, and it wants an restart. The source was through FF.
A) Can it be cleaned up, and how?
B) Can I prevent this from happening again?
I have a sample, will upload.
Win 10; Aud 2.2.1.
Is the waveform clipped? Did you accidentally turn up the volume slider in the Track Control Panel?
Hi Bill.
No.
I also refreshed FF and tested a new recording, same source. Clear as a bell.
Since the new recording sounds perfectly clear, it seems the issue might be with the original recording rather than your playback settings. Check whether the original waveform shows clipping or distortion, as that can be difficult to fix completely afterward. You could also try normalizing a copy and see if it makes any difference. If the distortion is already baked into the recording, preventing it during recording is usually the best approach.
