Directory for AUP3 files.
Hello everyone. I noticed that my .AUP3 files are stored on Drive C: under “Documents\Audacity”. Since my Drive C: is an SSD drive and has less memory than my other drives, how can I store my AUP3 files somewhere else? On another Hard Drive and Folder. Thanks in advance.
Windows - 10 (the most recent version)
Audacity 3.1.3.
Todd
There are settings in Preferences for the default Save / Import / Export directories. See: Directories Preferences - Audacity Manual
Note that when Saving or Opening projects, normal internal drives should be used. External drives, network drives, and cloud drives may corrupt AUP3 projects that are open (such drives are usually OK for AUP3 projects that are not open).
