Hi,
I downloaded EXE installers 32/64-bit on page Audacity ยฎ | Download for Windows
but there is at last SHA-256 checksum. ![]()
ah danmit. That indeed appears to be the case. Weโll fix it very soon.
Done. Thanks.
Probably related, so Iโll post it here - winget upgrade is not working. Hereโs the message I get:
C:\WINDOWS\system32>winget upgrade --all
Name Id Version Available Source
Audacity 3.7.3 Audacity.Audacity 3.7.3 3.7.4 winget
WD Security WesternDigital.Security 2.1.0.130 2.1.4.358 winget
Microsoft Visual C++ 2015-2022 Redistributable (x86) - 14.44.35112 Microsoft.VCRedist.2015+.x86 14.44.35112.1 14.44.35208.0 winget
3 upgrades available.
1 package(s) have version numbers that cannot be determined. Use --include-unknown to see all results.
4 package(s) have pins that prevent upgrade. Use the โwinget pinโ command to view and edit pins. Using the --include-pinned argument may show more results.
(1/3) Found Audacity [Audacity.Audacity] Version 3.7.4
This application is licensed to you by its owner.
Microsoft is not responsible for, nor does it grant any licenses to, third-party packages.
Downloading https://github.com/audacity/audacity/releases/download/Audacity-3.7.4/audacity-win-3.7.4-64bit.exe
โโโโโโโโโโโโโโโโโโโโโโโโโโโโโโ 17.1 MB / 17.1 MB
Installer hash does not match; this cannot be overridden when running as admin
All fixed now!
