Can I interpret a recording to the extent that I can pick out the musical notes? If so what is the process?
Thanks,
BobE
Thanks,
BobE
With “normal” music this is difficult because there are usually multiple instruments and vocals, often playing chords and/or different notes.
If you select/highlight part of the track, then Analyze → Plot Spectrum, you’ll see the frequency spectrum. As you move the cursor across the spectrum display the frequency and associated musical note will be displayed.
