Deleting false starts and endings due to copying my Vinyl records using DENON 450USB turntable to WAV
I’m pretty useless with computers. I have been recording my LPs using my DENON 450USB into WAV files. But cuing the record caused some false starts. I just want to delete the false starts at the beginning of each LP. The rest of the LP recorded ok. 1.For windows11 what version Audacity should I get? 2.What function would I use in Audacity to delete the false starts? Also, some of the recordings have the sound of the needle lifting at the ending. Obviously I’m a newbie (:>)
This is as simple as selecting the unwanted portion of the wave file and pressing the delete key.
It is usually visually obvious what parts of the recording need to be removed.
It may be a little less obvious that you need to save the wav file using “export audio” rather than just saving the audacity project.
The latest version fully released will be version 3 and this is what you should use.
I also suggest downloading 3.7.7 (latest one) but watch out for the trap to try to get you to sign up to something you might not need. If you like having more than one option, also try out Ocenaudio, which is also free. Audacity uses its own project file format whereas Ocenaudio allows you to edit and save as WAV. It’s also faster, more stable and arguably easier to use but it has fewer features than Audacity. Horses for courses, really.
I see your turntable allows recording to a USB stick, a clever touch. I assume you will shove the stick in your Windows PC and edit it from there.
Thanks for the suggestion! As I said, I’m useless with computers, but I have a friend who uses Audacity to work with his downloaded LP music. I will ask him what he thinks of Ocean? Unfortunately he’s on Vacation right now. I’m always fearful of doing anything on my PC.
Thanks for the info! As I stated to MarkB I will wait to hear from my friend on what to do next. I don’t want to make a mistake. I has taken several hours to download 10 LP’s so far. I’m taking it slow. However I am impatient so I got on to this forum (:>) By the way, the DENON was defective and so was the USB stick. I got the replacement DENON and USB stick and then discovered that my NAD CD/USB player does not play WAV files. But WAV is “lossless”, so I decided to continue with WAVs.
No problem.
Oh dear, not the best starting point for doing something new, eh? I am hoping these YouTube videos might clarify things a bit:
  1. Recording vinyl records - 1
  2. Recording vinyl records -2
  3. Playlist of video tutorials for Ocenaudio
There is also this section in the Audacity manual: Digitising LPs and tapes
Could you tell us a bit more about the NAD device so I can find out about it, please?
Thanks again, evilmrb! I’ll have to watch all the videos.
Lately I spend all my “spare” time watching youtube (:>)
Yep, I know the feeling!
I watch a lot of music videos. If you haven’t seen his videos, one Guy that’s quite good is Rick Beato, although I’m an older guy so it might not be to your taste.
I am an older guy too and it IS my taste.
That’s good news (:>) Most of my LPs are 60’s rock,plus most other categories. Beato has some great interviews.
I won’t be able to finish this topic in the time frame, so I may have to change the subject. But suffice it to say that I watched your 3 videos, Mark B. My friend came over and we tried the OcenAudio which he said behaves much like Audacity. I spent 29,95 on Nero but the wrong program. I would like to export WAV from OcenAudio to Nero. Do I need Nero Platinum? I want to limit my expense. Also I am using a DENON 450usb and your video created another question. I have no idea what the resolution is. I may see if DENON has answers. But I already bought the DENON so no choice. In the meantime, I’m VERY SLOW with this stuff. It may take weeks to understand this.
Why do you think you have the wrong program? Which version did you get? Could you get a refund, maybe? You could use CDBurner XP for free.
Do you realise you still need to split the WAV into tracks if you want to be able to play selected tracks or skip them?
How would it be if I send you a private message with my details so I can help outside of the forum? I think it might be an idea for you to send me one of your LP captures for me to experiment with. What do you reckon?
Thanks a million, Mark. As a newbie I’m like a babe in the woods. I ordered Nero from the microsoft store. I’ll see if I can get a refund. In the meantime I’ve downloaded CDBurnerXP and I’ll try it out. (Here’s a 'sidebar question-- I would like to donate something to these independent software developers but have always been concerned that my credit card may be compromised. Any ideas on contributing safely?)
I’m slightly embarrassed to say I don’t do that as much as I should so I can’t help a great deal. To make matters worse almost all the software I use is free/open-source. To that end, I use Linux rather than Windows. If I can avoid Windows for all eternity, I will.
I’ve read good things about that software but I’m not really a Windows person.
Thanks XYXero! Since I am computer challenged, it would take me a Looooong time to try all these solutions. However I really appreciate the assistance I am getting for all of you. It will take me a lot of effort to investigate, but, the suggestions are there!
Since I am fearful when it comes to credit card transactions, I think I may just avoid it altogether. One idea I had was to use “dollar bills in an envelope with no return address” as I don’t want to use “traceable” things like money orders or cheques (anything with my address on it). But dollar bills are also risky. Too bad crooks are out there.
I have trouble enough with windows, I would never use Linux …steep learning curve.
I’ll try to find VinylStudio however I’m already challenged with all the suggestions so far. It would take me weeks to find and evaluate all of this.
