Hi there
I know how to set the default visualization to spectrogram, but haven’t found a way to open files with my preferred settings.
Please let me know, if there’s any .ini or some preferences file that I could edit in order to use my spec settings by default, which would be
logarithmic 50 - 20000 Hz
Gain +40 dB, Range 40 dB, High Boost +18 dB/dec, Grayscale
There is: Setting up multiple user profiles or whole machines and writing this config file into the user’s AppData folder via a batch script. This makes sure, every current and future user has identical default settings
