Did some recordings and then stupidly formatted the SD card.
Doing a raw data dump from card contents to disk I can clearly see the old files.
The header starts as:
RIFFøS)WAVE
Hex:
52 49 46 46 F8 53 29 0C 57 41 56 45
The main issue I’m having is that while using audacity to open the raw data, I get an echo. It’s as if everything repeated 1 second after first coming into play.
Frankie,
If you still have the SD card in its formatted state ie you haven’t re-used it, you could try recovering from it directly. If you are a Windows user (or have access to Windows) you could try QtPhotoRec which uses file carving to find certain file types. It’s free so you have nothing to lose. I’ve had good results with it. Make sure you use the GUI (QtPhotoRec) rather than PhotoRec which is a text-based program.
There are some other suggestions here: Free Data Recovery Software.
Good luck.
Mark B
Frankie,
I’m very impressed by what you have done. Having figured out a solution, written a program to fix it, shared and documented it, you round the job off with a well-written story of the whole thing. You have my admiration. Maybe you should share your fix with Zoom or post something in their forum too, if they have one.
Mark B
