Hi,
I had to reinstall the program because my computer crashed (WIndows10, 64). Everything works fine except de-esser and de-clicker. Is there anything else I should install to help make this work?
regards, Natasa
In the latest version of Audacity, De-Clicker & De-Esser appear in a folder named “n/a” …
Once installed and enabled and Audacity restarted.
Hi, Trebor and thank you for the reply.
I think I have them in the right folder. I would like to send a picture, but do not know how.
As I can see, both addons are in an folder Plug-ins. Should I put them in some other folder?
Here they are in my Tool - Manage PlugIns - and enabled
De-Esser Nyquist C:\Program Files\Audacity\plug-ins\DeEsser.ny
De-Esser Nyquist C:\Users\natas\AppData\Roaming\audacity\Plug-lns\DeEsser.ny
(I tried to use both, but no success)
and
De-Clicker Nyquist C:\Program Files\Audacity\plug-ins\DeClicker.ny
I am not a computer expert and probably did a lot of wrong settings.
Regards, Natasa
Ha again,
I solved the problem. I asked CGTP and found out that I had the apps in wrong folder. I put them in the right one ant tested and is OK.
Thank you for your help and have a nice day!
regards, Natasa
HA! Was just going to state that sometimes the plugins don’t work the best for me. Purely trial/error
Try the desibilator version of the de-esser.
