Cutting down multiple audio files at the same time
I currently have 30 separate audio files, each of them 3 seconds long. I want to cut them all down to 0.1 seconds. How do I do this quickly? So far I’ve been opening one file at a time, selecting 0.1 seconds worth of audio, then doing export selection.
If I open all of them at once, and shift-click to select a 0.1 second interval for all of them, I’m stuck with nothing to export. Export multiple will export their entire length, and export selection will combine them all to a single file - and I want to keep them separate.
Any ideas on how to do this? Thanks!
Have you looked at the Chain commands? Chains is the Audacity version of Batch Processing.
http://manual.audacityteam.org/o/man/batch_processing.html
The first 0.1 seconds, the last 0.1 seconds, the middle 0.1 seconds, or some other 0.1 seconds?
Any 0.1 seconds, the audio files are square waves so I don’t mind where the .1 seconds come from
One way to do it:
Import all of the files.
Select 0.1 seconds in one of the tracks.
Ctrl+Shift+K to “Select in all tracks”.
Ctrl+T to trim
File menu > Export Multiple (based on tracks).
