cut a large mp3 file
Hallo,
I want to cut a large mp3 File (450Mb ; 15 hours) in 5 min parts. The parts shuould be saved in the right order.
Is that possible with Audacity?
If yes please explain it.
I use mac OS High Sierra 10.13.6 and Audacity 2.3.3
Thanks
alberich
You could do that in Audacity, but Audacity will resample and reduce the sound quality while it’s doing it. Much better one of the “pure” MP3 editors that doesn’t resample the sound. MP3Cut??
This tutorial is about transferring LPs and tapes to digital, but the principle is the same.
– Bill
If you want exactly 5 minutes (300 seconds), then you can
use “Regular Interval Labels” to add a label every 300 seconds (see: Regular Interval Labels - Audacity Manual)
and then “Export Multiple” based on labels (see: Exporting multiple audio files - Audacity Manual)
