Custome waveform and tone generations
hello guys
this is dr kedar
i am very new to audacity.
i want help from you guys
i want to generate tones using audacity.
here i am mixing two waveforms together square and sawtooth
and creating a .wav file at the end
please refer to following video
problem is the whole process is taking much time.
i want to generate thousands to tones , the process is same but number will change
eg
i select 50 hz square wave
add more tone of 50 hz sawtooth wave & combine both waveforms
then
second trach 100 hz square wave
add 100 hz sawtooth wave and combine both 100 hz waves
now i get 50 hz & 100 hz tracks with custom waveform
and export this track as wav
is there a wav that i save the custom waveform as preset and just change the tone numbers and quickly create .wav files.
Try running this code in “Tools menu > Nyquist Prompt”:
;type generate
;control hz "Frequency (Hz)" float-text "" 40 0 nil
;control dur "Duration" time "" 30 0 nil
(let ((sqwav (stretch dur (osc-pulse hz 0)))
      (sinwav (osc (hz-to-step hz) dur *saw-table* -90)))
  (mult 0.5 (sum sqwav sinwav)))
Your saw-square combo is not very “Frequency Specific” :
Have a look at its frequency content
HELLO STEVE
HOW CAN I THANK YOU. IT WORKED WELL. I AM SO MUCH GREATFUL
CAN I ASK MY FEW OTHER QUERIES PLEASE
No need to ask if you can ask.
If you have further questions about a reply, just ask the question. If your other question is not directly related to this topic, start a new topic.
