Newly installed Audacity. When I open a file and click Play, the playback starts but the cursor does not move. If I click somewhere in the empty space in the window, the cursor is updated to the current position but still does not move after that.
Rebooted. I have previously used Audacity on the same PC but under Windows, problem did not occur there.
I’m maybe late to this, but I appear to have the same issue with the cursor/marker.
I wish to try Steve’s fix, but am not sure where exactly to apply the revised code. There appear to be several .desktop files!
Any help for this newb would be appreciated.
Ta
I’m using linux via chrome os which while not supported directly, does appear to work - with the exception of the cursor bug.
version 2.4.2
installed via flathub/flatpak
I’m very new to linux and so am learning quickly (from the deep end).
I will keep researching as I still have that issue of teh cursor not tracking along with the audio as I play things (I did try installing an older version of Audacity and it did appear to work though).
Hi, using Audacity 3.6.1 on Ubuntu 24.10 with Wayland on an Nvidia graphics card.
The thin vertical playback cursor updates only about once a second at first and this gradually slows down to one update every 15 seconds. Audio plays fine.
If I click the cog wheel in the upper lefthand corner and select Continuous scrolling, the audio data scrolls at maybe 10-15 fps for a few seconds, then the waveform window becomes a dark grey rectangle.
Running instead in an Xorg session works (=smooth movement of the cursor), but as Wayland is the default in Ubuntu now that does not seem to be the way forward.
I tried as suggested above to edit /usr/share/applications/audacity.desktop to include
