Curiosity
Is the ability to set a path to an opening graphic only available when loading a new version? You know, …the Audacity graphic that shows when opening the program.
Are you referring to the “splash screen”?
If so, that screen is coded into Audacity. If you wish to modify it, you would need to get a copy of the Audacity source code, modify it, and build your own custom version of Audacity.
OK, thanks Steve. I only ask because I thought I saw a field showing the path to the splash screen, when I was loading up the latest Audacity version.
I just glanced at it, at the time. Not sure though.
Doesn’t really matter. Was just the curiosity of a graphic artist. Haha.
