Also error report failed to send. This one is different from 118642 bc I’m not using any plugins. The crash came on my first time running Audacity after installation and its never been installed on this PC before. Windows 11 w/ latest updates. I was trying to batch convert some YouTube .wav rips via Tools > Apply Macro > MP3 Conversion. These are each several hundred MB.
The rest of the crash report is attached
crash_report.txt (307.1 KB) as a .txt
GPU is an integrated Ryzen 7 series. EDIT: pasted some code
10.0.22631 4317
CPU: amd64
family 25 model 80 stepping 0
16 CPUs
GPU: UNKNOWN
Crash reason: EXCEPTION_ACCESS_VIOLATION_READ
Crash address: 0xa0
Process uptime: 143 seconds
Thread 0 (crashed)
0 wxbase313u_vc_x64_custom.dll + 0x2fe3e
rax = 0x00000a19efc61e12 rdx = 0x0000000000000088
rcx = 0x000000108c4fc2d0 rbx = 0x000000108c4fc2d0
rsi = 0x0000016792f38140 rdi = 0x000000108c4fc2d0
rbp = 0x000000108c4fc290 rsp = 0x000000108c4fc0e0
r8 = 0x000000108c4fc2d0 r9 = 0x000000108c4fc010
r10 = 0x000000108c4fbdb0 r11 = 0x000000108c4fbf00
r12 = 0x0000000000000000 r13 = 0x0000000000000002
r14 = 0x0000016792f56620 r15 = 0x0000016792f4d780
rip = 0x00007ffe594efe3e
Found by: given as instruction pointer in context
Stack contents:
000000108c4fc0e0 00 00 00 00 00 00 00 00 30 00 00 00 00 00 00 00 ........0.......
000000108c4fc0f0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
000000108c4fc100 88 00 00 00 00 00 00 00 9a 45 fc 65 fe 7f 00 00 ........Eüeþ...
Possible instruction pointers:
1 lib-strings.dll + 0x459a
rbp = 0x000000108c4fc290 rsp = 0x000000108c4fc110
rip = 0x00007ffe65fc459a
Found by: stack scanning
