I’m fairly new to cutting playlists together, but I’ve done it a bit with audacity. My issue is that the crossfade clips function is behaving strangely. Instead of blending the two selected pieces of song together, it’s just fading out the first and fading in the second. there is no transition at all that I can see. I’m not sure if I accidentally changed some sort of setting or what, but I can’t figure it out. Could someone help me understand what’s going on? Many thanks!
Topic moved to Windows forum.
Which version of Audacity are you using?
There are two “crossfade” effects. Ensure that you use the right one for your task:
https://manual.audacityteam.org/man/crossfade_clips.html
https://manual.audacityteam.org/man/crossfade_tracks.html
