Vista 32bit
Audacity 2.0
Installed from .exe installer
I wish to create a .cue file using ‘Label2cue’ to be able to burn to a cdr, but am not 100% sure of how to go about it.
Can I import individual flac files, merge/join them, create labels then save to my harddrive and then use that information to create the CUE file?
Or do I have to use WAV?
What is the best way to merge/join them: Use the ‘time shift tool’ or use ‘Find zero crossings’ and then ‘cut’ and ‘paste’ to create one long file or doesn’t it matter?
What I want to know is if there is only one way to export my project to be able to create a CUE file, because I don’t want to waste time doing it one way and discovering it doesn’t work.
I don’t know if you need any other information.
Thanks
