Create multiple songs from one song
It’s been over 20 years since using audicity, so I’ve forgotten everything. I downloaded a live concert of Chick Corea and all 4 or 5 tracks or songs were in one track. I imported the file into audacity, but cant remember how to separate each track within the original single track. I was able to name each song at the bottom of the recordings. how do I split the track into multiple tracks please?
If you’ve already labeled the songs, Export Multiple.
Otherwise, you can select/highlight one song at a time and Export Selection, one at a time.
And since there probably isn’t silence between tracks, you’ll want to re-open the songs (one a at a time) and fade-in and fade-out.
Ideally on separate live tracks I like a short fade-in of the applause/crowd noise of 1-2 seconds. Then a longer applause fade-out at the end, depending on what you have to work with.
