First, please note that I’m not an expert by any means. I use Audacity to edit a podcast. Just tonight when I try to Export, it crashes.
I tried to reinstall and that just got messy. Nothing would install.
Here is my log. Anyone help?
22:38:39: Audacity 3.2.4
22:38:39: sqlite3 message: (1) no such table: project in “SELECT 1 FROM project LIMIT 1;”
22:38:39: Error: Failed to load shared library ‘avformat-59.dll’ (error 126: The specified module could not be found.)
22:38:39: Error: Failed to load shared library ‘avformat-58.dll’ (error 126: The specified module could not be found.)
22:38:39: Error: Failed to load shared library ‘avformat-57.dll’ (error 126: The specified module could not be found.)
22:38:39: Error: Failed to load shared library ‘avformat-55.dll’ (error 126: The specified module could not be found.)
22:38:42: Loaded 92 string 1.955078 Kb in size
22:38:42: Project loaded in 183 ms
22:39:30: Help button pressed: PageName Quick_Help, releasePageName quick_help.html
22:39:30: webHelpPage Getting Started - Audacity Manual, localHelpPage C:\Program Files\audacity\help\manual\quick_help.html
