ALSA lib pcm_dsnoop.c:638:(snd_pcm_dsnoop_open) unable to open slave
ALSA lib pcm_dmix.c:1108:(snd_pcm_dmix_open) unable to open slave
ALSA lib pcm.c:2564:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2564:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2564:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
ALSA lib pcm_oss.c:377:(_snd_pcm_oss_open) Unknown field port
ALSA lib pcm_usb_stream.c:486:(_snd_pcm_usb_stream_open) Invalid type for card
21:01:25: Debug: ScreenToClient cannot work when toplevel window is not shown
Expression ‘ret’ failed in ‘src/hostapi/alsa/pa_linux_alsa.c’, line: 1736
Expression ‘AlsaOpen( &alsaApi->baseHostApiRep, params, streamDir, &self->pcm )’ failed in ‘src/hostapi/alsa/pa_linux_alsa.c’, line: 1904
Expression ‘PaAlsaStreamComponent_Initialize( &self->capture, alsaApi, inParams, StreamDirection_In, NULL != callback )’ failed in ‘src/hostapi/alsa/pa_linux_alsa.c’, line: 2171
Expression ‘PaAlsaStream_Initialize( stream, alsaHostApi, inputParameters, outputParameters, sampleRate, framesPerBuffer, callback, streamFlags, userData )’ failed in ‘src/hostapi/alsa/pa_linux_alsa.c’, line: 2840
Expression ‘stream->playback.pcm’ failed in ‘src/hostapi/alsa/pa_linux_alsa.c’, line: 4628
21:01:26: Debug: ScreenToClient cannot work when toplevel window is not shown
21:01:26: Debug: ClientToScreen cannot work when toplevel window is not shown
21:01:27: Debug: Unrecognized accel key ‘backspace’, accel string ignored.
21:01:27: Debug: Unrecognized accel key ‘numpad_enter’, accel string ignored.
21:01:27: Debug: ClientToScreen cannot work when toplevel window is not shown
21:01:27: Debug: ScreenToClient cannot work when toplevel window is not shown
*** BUG ***
In pixman_region32_init_rect: Invalid rectangle passed
Set a breakpoint on ‘_pixman_log_error’ to debug
*** BUG ***
*** BUG ***
*** BUG ***
*** BUG ***
21:01:42: Debug: ScreenToClient cannot work when toplevel window is not shown
21:01:42: Debug: ClientToScreen cannot work when toplevel window is not shown
21:01:42: Debug: Unrecognized accel key ‘backspace’, accel string ignored.
21:01:42: Debug: Unrecognized accel key ‘numpad_enter’, accel string ignored.
*** BUG ***
*** BUG ***
*** BUG ***
21:01:46: Debug: ScreenToClient cannot work when toplevel window is not shown
21:01:46: Debug: ClientToScreen cannot work when toplevel window is not shown
21:01:46: Debug: Unrecognized accel key ‘backspace’, accel string ignored.
21:01:46: Debug: Unrecognized accel key ‘numpad_enter’, accel string ignored.
*** BUG ***
*** BUG ***
21:01:51: Debug: ScreenToClient cannot work when toplevel window is not shown
21:01:51: Debug: ClientToScreen cannot work when toplevel window is not shown
21:01:51: Debug: Unrecognized accel key ‘backspace’, accel string ignored.
21:01:51: Debug: Unrecognized accel key ‘numpad_enter’, accel string ignored.
Segmentation fault (core dumped)
