I use Windows 10. Ever since V3.6.1, I experience crashes. Now with 3.6.3., the program crashes with every export audio. The result is still there but this is extremely annoying. And every time I click on send, the messages comes that the crash report could not be sent. I see that you know about this since May but haven’t fixed it. It really undermines confidence, folks!
Unfortunately I’ve had the same issues. Just installed 3.6.3 in Windows 10/64bit and hoping it would have solved the problem but no go. Won’t send crash report here either. It did say on installation that it wouldn’t use OpenVimo as it wasn’t compatible. I just came over from 3.6.2 after years with Adobe and I don’t want to go back.
Hopefully a fix will still come
Cheers
@bearonbanjo please provide the steps that we need to take to reproduce the crash. Also, what system are you on? I’m trying to export using various formats but couldn’t reproduce the crash so far.
Updated to 3.6.3 yesterday. I just exported 8 MP3 files this morning and it did not crash on export. I closed projects several times between exports with no problem till the last one. When I hit CNTL W to close, it crashed just like it was doing every time on 3.6.1.
I saved the crash report to a text file if it would be of any help.
What do you mean “what system are you on”? I said I’m on Windows 10/64 using Audacity 3.6.3, so what else are you looking for? The make of my laptop?
As to reproducing, next time this happens and the software tells me that it cannot send the crash report, where should I send it? I can copy it out but I read on this chat that someone else was not able to save the entire crash report due to limitation of space.
Another problem with 3.6.3. When I select a portion a 5-hour project to export, it exports the whole thing.
THIS IS THE ERROR MESSAGE I GOT TODAY:
iF YOU ARE INTERESTED IN GETTING THE REST, SINCE YOUR SYSTEMS DON’T ALLOW FOR YOU TO RECEIVE MORE, GIVE ME AN EMAIL ADDRESS TO WHERE i CAN SEND IT!
Operating system: Windows NT
10.0.19045 4894
CPU: amd64
family 6 model 140 stepping 1
8 CPUs
GPU: UNKNOWN
Crash reason: EXCEPTION_ACCESS_VIOLATION_READ
Crash address: 0x52f
Process uptime: 218 seconds
Thread 0 (crashed)
0 wxbase313u_vc_x64_custom.dll + 0x41da0
rax = 0x00007ffeae4e6068 rdx = 0x000000000000052f
rcx = 0x000002653a54d150 rbx = 0x000002653a599a10
rsi = 0x000002653a599970 rdi = 0x000002653a599a18
rbp = 0x000002653a59a990 rsp = 0x00000099202fc7f8
r8 = 0x0000000000000000 r9 = 0x00000099202fc501
r10 = 0x0000000000008000 r11 = 0x00000099202fc7d0
r12 = 0x000002653a5286e0 r13 = 0x0000000000000020
r14 = 0x00000265373ba030 r15 = 0x00000265373ba000
rip = 0x00007ffeae2f1da0
Found by: given as instruction pointer in context
Stack contents:
00000099202fc7f8 15 99 57 18 ff 7f 00 00 ..W.ÿ...
Possible instruction pointers:
1 lib-viewport.dll + 0x9915
rbp = 0x000002653a59a990 rsp = 0x00000099202fc800
rip = 0x00007fff18579915
Found by: simulating a return from leaf function
Stack contents:
00000099202fc800 01 ce 2f 20 99 00 00 00 10 9d 41 37 65 02 00 00 .Î/ ......A7e...
00000099202fc810 38 c8 2f 20 99 00 00 00 70 99 59 3a 65 02 00 00 8È/ ....p.Y:e...
00000099202fc820 00 00 6a 78 f4 7f 00 00 28 cc 2f 20 99 00 00 00 ..jxô...(Ì/ ....
00000099202fc830 a7 00 28 01 00 00 00 00 50 28 f2 43 65 02 00 00 §.(.....P(òCe...
00000099202fc840 50 28 f2 43 65 02 00 00 50 28 f2 43 65 02 00 00 P(òCe...P(òCe...
00000099202fc850 a0 bd 4e b0 fe 7f 00 00 ½N°þ...
2 lib-track.dll + 0x2bda0
rbp = 0x000002653a59a990 rsp = 0x00000099202fc858
rip = 0x00007ffeb04ebda0
Found by: stack scanning
Stack contents:
00000099202fc858 81 1b 4c b0 fe 7f 00 00 ..L°þ...
3 lib-track.dll + 0x1b81
rbp = 0x000002653a59a990 rsp = 0x00000099202fc860
rip = 0x00007ffeb04c1b81
Stack contents:
00000099202fc860 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000099202fc870 28 cc 2f 20 99 00 00 00 12 b7 64 ae fe 7f 00 00 (Ì/ .....·d®þ...
4 wxmsw313u_core_vc_x64_custom.dll + 0xb712
rbp = 0x000002653a59a990 rsp = 0x00000099202fc880
rip = 0x00007ffeae64b712
Stack contents:
00000099202fc880 a7 00 28 01 00 00 00 00 00 00 00 00 00 00 00 00 §.(.............
00000099202fc890 50 28 f2 43 65 02 00 00 50 28 f2 43 65 02 00 00 P(òCe...P(òCe...
00000099202fc8a0 50 28 f2 43 65 02 00 00 a0 bd 4e b0 fe 7f 00 00 P(òCe... ½N°þ...
5 lib-track.dll + 0x2bda0
rbp = 0x000002653a59a990 rsp = 0x00000099202fc8b0
Stack contents:
00000099202fc8b0 81 1b 4c b0 fe 7f 00 00 ..L°þ...
6 lib-track.dll + 0x1b81
rbp = 0x000002653a59a990 rsp = 0x00000099202fc8b8
Stack contents:
00000099202fc8b8 00 00 00 00 00 00 00 00 a8 cf 2f 20 99 00 00 00 ........¨Ï/ ....
00000099202fc8c8 00 00 00 00 00 00 00 00 46 02 00 00 00 00 00 00 ........F.......
00000099202fc8d8 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000099202fc8e8 21 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 !...............
00000099202fc8f8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000099202fc908 00 00 00 00 00 00 00 00 00 00 2f 37 65 02 00 00 ........../7e...
00000099202fc918 30 a0 3b 37 65 02 00 00 30 a0 3b 37 65 02 00 00 0 ;7e...0 ;7e...
00000099202fc928 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000099202fc938 70 99 59 3a 65 02 00 00 ff ff ff ff 00 00 00 00 p.Y:e...ÿÿÿÿ....
00000099202fc948 09 cb 2f 20 99 00 00 00 60 99 59 3a 65 02 00 00 Ë/ ....`.Y:e...
00000099202fc958 2b b0 57 18 ff 7f 00 00 +°W.ÿ...
7 lib-viewport.dll + 0xb02b
rbp = 0x000002653a59a990 rsp = 0x00000099202fc960
rip = 0x00007fff1857b02b
Stack contents:
00000099202fc960 01 91 c4 43 65 02 00 00 46 02 00 00 ff 7f 00 00 .ÄCe...F...ÿ...
00000099202fc970 2f 05 00 00 00 00 00 00 38 c8 2f 20 99 00 00 00 /.......8È/ ....
00000099202fc980 70 99 59 3a 65 02 00 00 60 99 59 3a 65 02 00 00 p.Y:e...`.Y:e...
00000099202fc990 30 a0 3b 37 65 02 00 00 6b 3a 43 ae fe 7f 00 00 0 ;7e...k:C®þ...
8 wxbase313u_vc_x64_custom.dll + 0x183a6b
rbp = 0x000002653a59a990 rsp = 0x00000099202fc9a0
rip = 0x00007ffeae433a6b
Stack contents:
00000099202fc9a0 ff ff ff ff 00 00 00 00 50 b9 9c 40 65 02 00 00 ÿÿÿÿ....P¹@e...
00000099202fc9b0 50 b9 9c 40 65 02 00 00 a0 fc 46 40 f6 7f 00 00 P¹@e... üF@ö...
9 Audacity.exe + 0x11fca0
rbp = 0x000002653a59a990 rsp = 0x00000099202fc9c0
rip = 0x00007ff64046fca0
Stack contents:
00000099202fc9c0 50 b9 9c 40 65 02 00 00 35 26 43 ae fe 7f 00 00 P¹@e...5&C®þ...
10 wxbase313u_vc_x64_custom.dll + 0x182635
rbp = 0x000002653a59a990 rsp = 0x00000099202fc9d0
rip = 0x00007ffeae432635
Stack contents:
00000099202fc9d0 30 a0 3b 37 65 02 00 00 c8 b5 2e ae fe 7f 00 00 0 ;7e...ȵ.®þ...
11 wxbase313u_vc_x64_custom.dll + 0x3b5c8
rbp = 0x000002653a59a990 rsp = 0x00000099202fc9e0
rip = 0x00007ffeae2eb5c8
Stack contents:
00000099202fc9e0 50 b9 9c 40 65 02 00 00 d8 ea f5 40 f6 7f 00 00 P¹@e...Øêõ@ö...
12 Audacity.exe + 0xc0ead8
rbp = 0x000002653a59a990 rsp = 0x00000099202fc9f0
rip = 0x00007ff640f5ead8
Stack contents:
00000099202fc9f0 50 b9 9c 40 65 02 00 00 ec 24 43 ae fe 7f 00 00 P¹@e...ì$C®þ...
13 wxbase313u_vc_x64_custom.dll + 0x1824ec
rbp = 0x000002653a59a990 rsp = 0x00000099202fca00
rip = 0x00007ffeae4324ec
Stack contents:
00000099202fca00 00 00 00 00 00 00 00 00 09 cb 2f 20 99 00 00 00 ........ Ë/ ....
00000099202fca10 43 5e aa ae fe 7f 00 00 C^ª®þ...
14 wxmsw313u_core_vc_x64_custom.dll + 0x465e43
rbp = 0x000002653a59a990 rsp = 0x00000099202fca18
rip = 0x00007ffeaeaa5e43
Stack contents:
00000099202fca18 50 b9 9c 40 65 02 00 00 00 00 00 00 00 00 00 00 P¹@e...........
00000099202fca28 06 02 00 00 00 00 00 00 a0 9a 5a 3a 65 02 00 00 ........ Z:e...
00000099202fca38 e5 2b 43 ae fe 7f 00 00 å+C®þ...
15 wxbase313u_vc_x64_custom.dll + 0x182be5
rbp = 0x000002653a59a990 rsp = 0x00000099202fca40
rip = 0x00007ffeae432be5
Stack contents:
00000099202fca40 5e 96 9e 40 f6 7f 00 00 ^@ö...
16 Audacity.exe + 0x69965e
rbp = 0x000002653a59a990 rsp = 0x00000099202fca48
rip = 0x00007ff6409e965e
Stack contents:
00000099202fca48 43 5e aa ae fe 7f 00 00 C^ª®þ...
17 wxmsw313u_core_vc_x64_custom.dll + 0x465e43
rbp = 0x000002653a59a990 rsp = 0x00000099202fca50
Stack contents:
00000099202fca50 50 b9 9c 40 65 02 00 00 43 5e aa ae fe 7f 00 00 P¹@e...C^ª®þ...
18 wxmsw313u_core_vc_x64_custom.dll + 0x465e43
rbp = 0x000002653a59a990 rsp = 0x00000099202fca60
Stack contents:
00000099202fca60 82 13 9e 2f ff 7f 00 00 ./ÿ...
19 USER32.dll + 0x21382
rbp = 0x000002653a59a990 rsp = 0x00000099202fca68
rip = 0x00007fff2f9e1382
Stack contents:
00000099202fca68 00 00 00 00 00 00 00 00 00 00 00 00 fe 7f 00 00 ............þ...
00000099202fca78 50 b9 9c 40 65 02 00 00 a0 1f 9c 2f ff 7f 00 00 P¹@e... ./ÿ...
20 USER32.dll + 0x1fa0
rbp = 0x000002653a59a990 rsp = 0x00000099202fca88
rip = 0x00007fff2f9c1fa0
Stack contents:
00000099202fca88 a0 1f 9c 2f ff 7f 00 00 ./ÿ...
21 USER32.dll + 0x1fa0
rbp = 0x000002653a59a990 rsp = 0x00000099202fca90
Stack contents:
00000099202fca90 00 00 00 00 00 00 00 00 a0 2c b9 31 ff 7f 00 00 ........ ,¹1ÿ...
00000099202fcaa0 82 13 9e 2f ff 7f 00 00 ./ÿ...
22 USER32.dll + 0x21382
rbp = 0x000002653a59a990 rsp = 0x00000099202fcaa8
Stack contents:
00000099202fcaa8 04 00 00 00 00 00 00 00 01 00 00 00 65 02 00 00 ............e...
00000099202fcab8 0e 92 2e 2f ff 7f 00 00 ../ÿ...
23 KERNELBASE.dll + 0x2920e
rbp = 0x000002653a59a990 rsp = 0x00000099202fcac0
rip = 0x00007fff2f2e920e
Stack contents:
00000099202fcac0 e0 c4 59 37 65 02 00 00 50 f0 ab e2 fe 7f 00 00 àÄY7e...Pð«âþ...
24 bdhkm64.dll + 0xcf050
rbp = 0x000002653a59a990 rsp = 0x00000099202fcad0
rip = 0x00007ffee2abf050
Stack contents:
00000099202fcad0 a0 2b 57 37 65 02 00 00 00 00 00 00 00 00 00 00 +W7e...........
00000099202fcae0 00 00 00 00 ff ff ff ff 00 00 00 00 00 00 00 00 ....ÿÿÿÿ........
00000099202fcaf0 48 00 00 00 00 00 00 00 01 00 00 00 ff 7f 00 00 H...........ÿ...
00000099202fcb00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000099202fcb10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000099202fcb20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000099202fcb30 92 e9 93 df 9f 46 00 00 80 f0 ab e2 fe 7f 00 00 éßF...ð«âþ...
25 bdhkm64.dll + 0xcf080
rbp = 0x000002653a59a990 rsp = 0x00000099202fcb40
rip = 0x00007ffee2abf080
Stack contents:
00000099202fcb40 98 cd 2f 20 99 00 00 00 01 00 00 00 00 00 00 00 .Í/ ............
00000099202fcb50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000099202fcb60 12 b7 64 ae fe 7f 00 00 .·d®þ...
26 wxmsw313u_core_vc_x64_custom.dll + 0xb712
rbp = 0x000002653a59a990 rsp = 0x00000099202fcb68
Stack contents:
00000099202fcb68 d4 5c 31 ae fe 7f 00 00 Ô\1®þ...
27 wxbase313u_vc_x64_custom.dll + 0x65cd4
rbp = 0x000002653a59a990 rsp = 0x00000099202fcb70
rip = 0x00007ffeae315cd4
Stack contents:
00000099202fcb70 00 00 00 00 fe 7f 00 00 30 a0 3b 37 65 02 00 00 ....þ...0 ;7e...
00000099202fcb80 00 00 00 00 00 00 00 00 98 cd 2f 20 99 00 00 00 .........Í/ ....
00000099202fcb90 00 00 00 00 00 00 00 00 ff ff ff ff ff ff ff ff ........ÿÿÿÿÿÿÿÿ
00000099202fcba0 98 cd 2f 20 99 00 00 00 58 cd 2f 20 99 00 00 00 .Í/ ....XÍ/ ....
00000099202fcbb0 01 00 00 00 00 00 00 00 fb cf 9e ae fe 7f 00 00 ........ûÏ®þ...
28 wxmsw313u_core_vc_x64_custom.dll + 0x3acffb
rbp = 0x000002653a59a990 rsp = 0x00000099202fcbc0
rip = 0x00007ffeae9ecffb
Stack contents:
00000099202fcbc0 12 b7 64 ae fe 7f 00 00 .·d®þ...
29 wxmsw313u_core_vc_x64_custom.dll + 0xb712
rbp = 0x000002653a59a990 rsp = 0x00000099202fcbc8
Stack contents:
00000099202fcbc8 00 00 00 00 00 00 00 00 00 00 02 00 00 00 00 00 ................
00000099202fcbd8 00 00 02 00 00 00 00 00 78 cd 2f 20 99 00 00 00 ........xÍ/ ....
00000099202fcbe8 82 13 9e 2f ff 7f 00 00 ./ÿ...
30 USER32.dll + 0x21382
rbp = 0x000002653a59a990 rsp = 0x00000099202fcbf0
Stack contents:
00000099202fcbf0 00 80 0f 20 99 00 00 00 00 00 03 00 00 00 00 00 ... ............
00000099202fcc00 30 25 68 78 f4 7f 00 00 00 00 03 00 00 00 00 00 0%hxô...........
00000099202fcc10 f8 cb 2f 20 99 00 00 00 00 00 00 00 00 00 00 00 øË/ ............
00000099202fcc20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000099202fcc30 a7 00 28 01 00 00 00 00 d4 5f 91 f9 51 39 00 00 §.(.....Ô_ùQ9..
00000099202fcc40 00 80 0f 20 99 00 00 00 00 00 00 00 00 00 00 00 ... ............
00000099202fcc50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000099202fcc60 98 cd 2f 20 99 00 00 00 00 00 00 00 00 00 00 00 .Í/ ............
00000099202fcc70 1f 03 00 00 00 00 00 00 39 e8 9d 2f ff 7f 00 00 ........9è./ÿ...
31 USER32.dll + 0x1e839
rbp = 0x000002653a59a990 rsp = 0x00000099202fcc80
rip = 0x00007fff2f9de839
Stack contents:
00000099202fcc80 46 02 00 00 00 00 00 00 00 00 02 00 00 00 00 00 F...............
00000099202fcc90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000099202fcca0 a8 cf 2f 20 99 00 00 00 00 00 00 00 00 00 00 00 ¨Ï/ ............
00000099202fccb0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000099202fccc0 00 00 00 00 00 00 00 00 b4 e7 9d 2f ff 7f 00 00 ........´ç./ÿ...
32 USER32.dll + 0x1e7b4
rbp = 0x000002653a59a990 rsp = 0x00000099202fccd0
rip = 0x00007fff2f9de7b4
Stack contents:
00000099202fccd0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000099202fcce0 c8 cd 2f 20 99 00 00 00 00 00 00 00 00 00 00 00 ÈÍ/ ............
00000099202fccf0 78 cd 2f 20 99 00 00 00 38 00 00 00 00 00 00 00 xÍ/ ....8.......
00000099202fcd00 98 cd 2f 20 99 00 00 00 70 f0 a4 2f ff 7f 00 00 .Í/ ....pð¤/ÿ...
33 USER32.dll + 0x8f070
rbp = 0x000002653a59a990 rsp = 0x00000099202fcd10
rip = 0x00007fff2fa4f070
Stack contents:
00000099202fcd10 00 00 00 00 00 00 00 00 e4 13 a3 31 ff 7f 00 00 ........ä.£1ÿ...
34 ntdll.dll + 0xa13e4
rbp = 0x000002653a59a990 rsp = 0x00000099202fcd20
rip = 0x00007fff31a313e4
Stack contents:
00000099202fcd20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000099202fcd30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000099202fcd40 78 cd 2f 20 99 00 00 00 58 00 00 00 2f 00 00 00 xÍ/ ....X.../...
00000099202fcd50 64 10 5c 2f ff 7f 00 00 d.\/ÿ...
35 win32u.dll + 0x1064
rbp = 0x000002653a59a990 rsp = 0x00000099202fcd58
rip = 0x00007fff2f5c1064
Stack contents:
00000099202fcd58 fc e8 9d ae fe 7f 00 00 üè.®þ...
36 wxmsw313u_core_vc_x64_custom.dll + 0x39e8fc
rbp = 0x000002653a59a990 rsp = 0x00000099202fcd60
rip = 0x00007ffeae9de8fc
Stack contents:
00000099202fcd60 64 06 06 00 00 00 00 00 d8 cd 2f 20 99 00 00 00 d.......ØÍ/ ....
00000099202fcd70 00 00 00 00 00 00 00 00 00 00 03 00 00 00 00 00 ................
00000099202fcd80 01 00 00 00 00 00 00 00 12 b7 64 ae fe 7f 00 00 .........·d®þ...
37 wxmsw313u_core_vc_x64_custom.dll + 0xb712
rbp = 0x000002653a59a990 rsp = 0x00000099202fcd90
Stack contents:
00000099202fcd90 10 d4 a2 31 ff 7f 00 00 .Ô¢1ÿ...
38 ntdll.dll + 0x9d410
rbp = 0x000002653a59a990 rsp = 0x00000099202fcd98
rip = 0x00007fff31a2d410
Stack contents:
00000099202fcd98 9a 07 08 00 00 00 00 00 1f 03 00 00 00 00 00 00 ...............
00000099202fcda8 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000099202fcdb8 88 7c 0c 00 2e 03 00 00 a3 01 00 00 00 00 00 00 .|......£.......
00000099202fcdc8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000099202fcdd8 33 a3 9c 2f ff 7f 00 00 3£/ÿ...
39 USER32.dll + 0xa333
rbp = 0x000002653a59a990 rsp = 0x00000099202fcde0
rip = 0x00007fff2f9ca333
Stack contents:
00000099202fcde0 05 00 00 00 00 00 00 00 00 00 64 ae fe 7f 00 00 ..........d®þ...
00000099202fcdf0 06 02 00 00 00 00 00 00 96 13 9e 2f ff 7f 00 00 ........./ÿ...
40 USER32.dll + 0x21396
rbp = 0x000002653a59a990 rsp = 0x00000099202fce00
rip = 0x00007fff2f9e1396
Stack contents:
00000099202fce00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000099202fce10 00 00 00 00 00 00 00 00 a8 cf 2f 20 99 00 00 00 ........¨Ï/ ....
00000099202fce20 00 00 00 00 00 00 00 00 30 a0 3b 37 65 02 00 00 ........0 ;7e...
00000099202fce30 05 00 00 00 00 00 00 00 00 00 64 ae fe 7f 00 00 ..........d®þ...
00000099202fce40 ff 3d 00 00 00 00 00 00 93 a2 9c 2f ff 7f 00 00 ÿ=......¢/ÿ...
41 USER32.dll + 0xa293
rbp = 0x000002653a59a990 rsp = 0x00000099202fce50
rip = 0x00007fff2f9ca293
Stack contents:
00000099202fce50 00 00 00 00 00 00 00 00 c0 3b 9a 38 65 02 00 00 ........À;8e...
00000099202fce60 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000099202fce70 01 00 00 00 99 00 00 00 00 00 00 00 00 00 00 00 ................
00000099202fce80 00 00 00 00 00 00 00 00 39 e8 9d 2f ff 7f 00 00 ........9è./ÿ...
42 USER32.dll + 0x1e839
rbp = 0x000002653a59a990 rsp = 0x00000099202fce90
Stack contents:
00000099202fce90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000099202fcea0 00 00 00 00 00 00 00 00 00 00 64 ae fe 7f 00 00 ..........d®þ...
00000099202fceb0 a0 9a 5a 3a 65 02 00 00 ed 1d 9f e2 fe 7f 00 00 Z:e...í.âþ...
43 bdhkm64.dll + 0x1ded
rbp = 0x000002653a59a990 rsp = 0x00000099202fcec0
rip = 0x00007ffee29f1ded
Stack contents:
00000099202fcec0 50 d8 2f 20 99 00 00 00 89 d7 2f 20 99 00 00 00 PØ/ ....×/ ....
00000099202fced0 ff ff ff ff 00 00 00 00 18 d2 2f 20 99 00 00 00 ÿÿÿÿ.....Ò/ ....
00000099202fcee0 01 00 00 00 99 00 00 00 06 fc 84 e2 fe 7f 00 00 .........üâþ...
Nothing has changed, guys, this is really annoying. If you don’t want to engage with your customers, then get behind this issue yourself and off the high developer horse that always says “it must be the customer, it can’t be our problem”.
I would recommend a little more patience. The developers are only trying to isolate the problem not lay blame. When offering advice on “customer engagement”, you might remind your self that this particular product is free.
To the developers (and the rest of you):
I have found that saving my project at regular intervals (often) during the edit process reduces or eliminates the crash at close issue. Hitting CTRL/S is not a big deal.
If it does crash at close, re-opening immediately and doing a recover always works and the loss of of work (if my first bullet is applied) is minimal.
My O/S is Win 10 22H2 home (with all service pack updates).
Thanks for the reminder that there’s always someone in the first row in class…
I would be much more patient, if there was a way to entrust the developers with the full information. As is, there’s no way to get through to them. And the attitude behind that is what infuriates. As to saving, those projects take up a large amount of space. But thanks for the hint anyway.
How does saving take up more space than close/save?
Anyways, have at it. Ill go yell at some clouds!
I tried going back to older versions. Versions 3.5.1 and 3.4.2 did not error on exit but still exported the complete project instead of what was selected. Do I need do a uninstall of Audacity to get rid of some setting left over when I install an older version?
Yes,having the same issue. Just installed 3.6.3 in Windows 10/64bit. Won’t send crash report . I just came over from 3.6.2 after years with Adobe and I don’t want to go back.
I have to restart computer every time I do one recording.
HELP
Thank you for solving this problem with the most recent release!
