Craking sound after mixing drums and instrumental.
Audacity version 2.4.2.0
Created several tracks (vocal, instrumental, precussion). After mixing theres a signal interfearence
at the start of the deep bass drum throughout song. Its not a T or pop P sound, it’s a light craking sound.
It’s a signal interference in messhing them, Completley destroys the mi.
How can this be corrected? WavePad program is perfect.
Mixing is done by summation so you can get [u]clipping[/u] (distortion).
If you are mixing 2 tracks you can reduce both tracks by -6dB (50%) and they won’t clip (assuming they weren’t already clipped). If you are mixing more tracks, of course they have to be reduced more.
Or, you can export as 32-bit floating-point WAV which can go over 0dB without clipping. Then re-import the mix and use the Amplify or Normalize effect to bring the level down again before exporting to your desired format.
