Hi,
I’m using Audacity 3.3.3 on MacOS Ventura 13.4.1
I’ve been using Audacity for years and never had a problem, but this week I had to update my computer to fix a problem in another application and then had to update Audacity as the older version I was using stopped working on the new OS. This issue started after I updated Audacity.
I keep hearing a crackling sound over audio I’ve imported. These audio tracks sound fine when played in other programs such as itunes. This has happened with two different mp3 files and with an audacity file that I recorded in the older version I had before the update. I’ve tried changing the buffer rate and it didn’t help. The sample rate is the same for all of these files and matches the settings I have in Audacity.
Any help would be greatly appreciated!
