Could use some tips/advice on my track
Hey guys!!
This is my very first post on here, so I’m very sorry if I break any rules. Just really stoked to have found a gateway to learning about Audacity and what it has to offer.
Big Bob Marley fan here, and I’ve recorded something using a Yeti microphone, my Taylor, and Audacity. I’ve attached the MP3 recording below (soundcloud).
https://soundcloud.com/navi-huang/waiting-in-vain-ivan-huang
I could really use some advice on what you pros are hearing are off/wrong with the recording. I use Audacity a lot, and I read up on how to utilize the settings, but I think getting advice from you guys is the best way to improve my adjustments. I believe I played around with the compressor, normalizer, and Gverb for this track.
I do have the raw Audacity file if any of you guys would be interested in taking a look.
Again, really brand new to this stuff, excited to hear what you guys have to say.
Ivan
That’s not turned out bad has it. Congratulations.
You know that we have an Audacity Sound Cloud group? You are very welcome to share your Audacity creations. https://forum.audacityteam.org/t/audacity-group-on-soundcloud-closed/35444/1
There’s something a bit weird going on with the reverb I think, but I can’t quite make it out - it could be due to the compression that they use on Sound Cloud. Would you be able to post a high quality version somewhere for us to listen to? (preferably WAV or Flac format - it doesn’t need to be the whole song, but including the start and the end would good.)
Hey Steve!
Thanks for the feedback - I’m hoping you get this reply as I’m still getting used to posting on the forum :slight_smile:
Gverb settings are below:
Roomsize: 6 m
Reverb time: 5 s
Damping: 0.75
Input bandwidth: 0.75
Dry signal: -5
Early Reflection: -60
Tail level: -35 db for vocals, -40/-45 for instruments
What’s the best place to post a WAV upload?
I’ve never been very keen on GVerb - I don’t think the original author of that effect ever intended it to be an end-user effect but rather for it to be a building block for developers to create more sophisticated reverb effects. As it turned out, it was the only reverb effect available in Audacity for many years.
The current version of Audacity has a much better (in my opinion) reverb effect: http://manual.audacityteam.org/o/man/reverb.html
There are also lots of free reverb plugins available - one favourite that gets mentioned a lot is Anwida dx reverb light http://www.anwida.com/product.asp?pid=7
Most of the free places are loaded with adverts, so be careful where you click :wink:
I usually use Sendspace - it allows up to 300 MB without registration. You can upload there, then copy the download link and post the link here.
I’ll move this topic to the “making music” part of the forum - just letting you know so that you don’t think it’s disappeared :slight_smile:
Hi brovanz,
Which Audacity version do you use?
I share Steve’s lack of enthusiasm regarding GVerb. But from Audacity 2.05 upwards, a really good Stereo Reverb has been included.
Let’s assume that 2.05 is indeed being employed and that you’ll require reverb to a four-track score. This is how it works.
  1. Highlight your first track (with Edit>Select>Cursor to track end) so as to make a copy.
  2. To be sure that this copy track lands exactly where it is in your original score, first create silence(Generate>Silence>OK) from 0.0 to just one or two seconds before your waveform starts. Leave open 2 seconds of silence after track end as well.
  3. Hit Copy (icon in the tool bar).
  4. Now open a fresh Audacity score (File>New). Subsequently, create a new track (Tracks>Add New>Audio).
  5. Paste the audio previously copied into your new track (with Paste, also on the tool bar). Make sure that this, too, starts from the exact 0.0 point (if you’re not certain, go to Transport>Skip to start).
  6. Duplicate your new track (Edit>Duplicate). An exact copy of your first new track will be added instantly.
  7. Before resorting to Stereo Reverb, you might want to reduce waveform strength a little. Standard Stereo Reverb settings are not always kind to your tracks - about which a little more later on. With this in mind, work on your source track first.
  8. Go to Effects>Amplify and reduce/enhance waveform output as required. If it shows much clipping, you’re strongly advised to reduce. Change the ‘Amplify’ value shown to -1.0 and take it in steps so as to decrease waveform volume to a level you’re satisfied with.
  9. Repeat 8. with the duplicate track, but make sure waveform here is reduced to 2.0/3.0 below your source track’s Amplification value. You’ll probably have to experiment a bit here.
  10. Make sure that volume and L/R, in source as well as duplicate tracks, are on 0/Centre respectively. Next, go to Effects once more (if your duplicate track is still highlighted) and scroll down to Plugins. Under Plug-ins 106-120, you’ll find Stereo Reverb.
  11. Stereo Reverb settings will now appear. Every value shown can be changed - and may have to be, since the standard application might result in solid blue where fuzzy wave should be seen. But usually a thin, elongated reverb track emerges that runs parallel to your source track.
  12. If you play the source track now, your instrument or vocal will sound as if in an immense hall. By pulling back the volume control button on what is now your reverb track, levels can easily be regulated.
  13. Save your ‘twin tracks’ (as.aup!). Repeat same procedure with tracks 2-4.
  14. Open a new score and paste all four sets of ‘twin tracks’ in there (in the same way as explained in 5.) Adjust L/R balance (reverb track’s should correspond with source track’s) and, if necessary, reverb levels. As to the latter: to much reverb started with in track 1 - and the same repeated in 2-4 - often leads to a messy result. Better to start with a modest level and increase to requirement.
  15. If balancing & reverb have been done to satisfaction, you might want to create a .wav audio file. Simply go to File>Export. A menu will appear with lots of stuff to choose from, but this all optional. Just hit OK - and after a minute or two, a freshly minted WAV audio file will be added.
  16. A variation on this is to begin with altering your source tracks to .wav, in the manner explained, and then to follow procedure as explained above.
  17. Finally, some help with changing Stereo Reverb settings, when required, may come in handy, too:
Here are some settings that may work nicely:
“The Quick Fix”
These settings add a slight sense of depth to any sound clip that is flat. While it won’t give you any sort of echo, it will give you the sense that you actually recorded it in a room where sound sort of bounces off.
Roomsize: 40 m²
Reverb time: 4 s
Damping: 0.9
Dry signal level: 0 dB
Early reflection level: -22 dB
Tail level: -28 dB
“Bright, small hall”
This is excellent if you want to create an effect which sounds like you are singing in a small, empty little poetry club.
Roomsize: 50 m²
Reverb time:1.5 s
Damping: 0.1
Dry signal level: -1.5 dB
Early reflection level: -10 dB
Tail level: -20 dB
"Nice hall effect "
This effect makes the audio clip sound like it was recorded in an empty music hall; not too big yet somewhat larger than a little room.
Roomsize: 40 m²
Reverb time: 20 s
Damping: 0.50
Tail level: -30 dB
"Singing in the Sewer "
This sounds exactly what its name suggests…
Roomsize: 6 m²
Reverb time: 15 s
Damping: 0.9
Input bandwidth: 0.1
Dry signal level: -10 dB
Tail level: -10 dB
“Last row of the church”
This is most likely the one you are looking for. The reverberation you can achieve with this effect will make vocals sound very rich and ethereal, even smoothing out some of the slight mess-ups you may have had in your voice.
Roomsize: 200 m²
Reverb time: 9 s
Damping: 0.7
Input bandwidth: 0.8
Dry signal level: -20 dB
Early reflection level: -15 dB
Tail level: -8 dB
Good luck!
tnob
