The Error when I launch audacity says:
"Could not find any audio devices.
You will not be able to play or record audio.
Error: Internal PortAudio error"
I have the latest version of audacity “2.1.1”
I have not been on the website that is said to stop audacity from working therefore cant download those files from it.
The Mic I use has been set up to be my default
The Mic is recognised and records through Fraps,Skype and Sound recorder.
I have checked my sound devices are up to date by doing
"Device Manager->Sound, video and game controllers-> Right click on all items in the dropdown list for Sound, video and game controllers-> Update driver software-> Search automatically for updated driver software.
I Don’t know what else to do so I really really need you’re help please!
This error is a known problem with Audacity on Windows 10 if any of the audio devices you are trying to use don’t have Windows 10 drivers that are fully compatible with the device. Have you read Missing features - Audacity Support?
According to Amazon.co.uk that mic works with Cortana. If so, we can assume it is compatible with Windows 10.
That being the case, it must be your built-in audio device (or one of its sub-devices) that is creating the error.
That only gives you the drivers that Windows can find. Assuming you have a branded computer like Dell or Lenovo, have you been to their site to see if there are Windows 10 audio drivers for your computer model? If not, try that.
Basicly when I was looking through the forums for this answer there was a site starting with a B that cause problems of you got files from it I can’t remember what said site was though
I hot my Pc from computer specialist which is a site where u decide what things you want for your PC so there won’t be a model number because it’s unique
The advice on Missing features - Audacity Support still applies. In your case go to the web site of the motherboard maker to see if they have Windows 10 drivers for your motherboard model number.
You can find basic information about the motherboard by installing CPU-Z.
Or type
dxdiag
in the Windows search box and press ENTER on your keyboard. DxDiag should show in the search results, so click on it.
Save the DxDiag report so you can refer to it. In the report, under “Sound Devices”, you should see a “Hardware ID” string for the built-in sound device. Mine is:
Make a note of the four characters following “VEN_” (Vendor) and the four following “DEV_” (Device). You should then be able to find out the manufacturer of the audio chip on the motherboard by entering those characters on http://www.pcidatabase.com/index.php.
If in the end you can’t find Windows 10 drivers for the motherboard audio, there are other solutions you can try on Missing features - Audacity Support.
If you were looking for drivers, I strongly recommend downloading drivers only from manufacturers’ sites. The majority of third-party sites offering drivers are scam sites that want to harm your computer.
THANK YOU SO MUCH !!! just did what you said to do (internet went down for a bit, I also forgot what my username was this so I made a new account and it now works so Thank you to kozikowski, cyrano and ESPECIALLY to Gale Andrews you guys have the best customer service than any other company so thank you so much !!!
