Corrupted .aup3 project (2.56GB DJ set) – sqlite3.rc:11 / SampleBlocks issue
Hello,
I need help recovering an Audacity project.
System:
  • Audacity: 3.7.5
  • Windows 10 (22H2)
Project information:
  • File type: .aup3
  • File size: 2.56 GB
  • Recording type: Single stereo DJ set recording (~1 hour)
  • No multiple tracks or complex editing
Error in Audacity:
sqlite3.rc: 11
SqliteSampleBlock::Load::step
“Audacity failed to read from a file”
What I tried:
  • Reinstalled Audacity
  • Opened project with DB Browser for SQLite
  • PRAGMA integrity_check initially completed without obvious errors
  • sampleblocks table exists and block IDs go up to 2602
  • Around blocks 2327–2449 fail when read
  • VACUUM INTO returns:
    “database disk image is malformed”
I was able to extract raw sample blocks with Python, but resulting WAV files are corrupted (wrong duration, heavy distortion/noise).
The original .aup3 file still opens in DB Browser and appears partially readable.
Could someone help me recover or extract the audio from this project?
Thank you.
Thank you very much for being willing to help.
I did not use Audacity Project Tools specifically. I only used Python scripts and DB Browser for SQLite to inspect the .aup3 file and attempt extraction.
What I found:
  • The .aup3 file is 2.56 GB
  • DB Browser opens the file
  • sampleblocks table exists (up to blockid 2602)
  • VACUUM INTO returns “database disk image is malformed”
  • I was able to extract raw sample blocks with Python, but the resulting WAV had incorrect duration and severe distortion
The recording is a single stereo DJ set (~1 hour), not a multitrack project.
I still have the original untouched .aup3 file.
I managed to do some kind of recovery using the Audacity project tools and another utility but it did have missing bits of audio.
