Corrupt or Otherwise Broken Audacity Project Recovery
thanks for trying, here is the aup3:
OK, so I took a look at your szb71_KRISZTIAN.aup3 project and was not able to make a recovery.
I am currently exploring some additional ideas, including Import Raw. This will take additional time.
Do NOT keep your hopes up.
Status Report:
Oh! Good news! I have been able to recover 2 hours and 15 minutes of stereo audio information that to the untrained eye, look good.
I still have some double-checking to do. Then I have to compress it and upload it - which will take a while. Not to mention I have several errands to run today as well as other obligations. But we can at least cross our fingers for now. :smiley:
OK, so I have PM’d you a link to the recovered, compressed file. :smiley:
Good Luck with it! :smiley:
it’s working, I’m overly happy about hearing it again. thanks a lot, you are a really good man - doing that cool things just for the sake of the community!
awesome!
Thanks for your report! :smiley:
This did not work for me. I keep getting the message “file is not a database”
How can I recover my file?
See this post from earlier in this topic: Corrupt or Otherwise Broken Audacity Project Recovery - #53 by jademan
Hi There. I have a problem with an audacity file (says “failed to read a file from C:” when i try to open it.). I tried using the tool but it doesn’t work for me. I get a load of errors along the lines of “The code execution cannot proceed because MSVCP140 dIl was not found. Reinstalling the program may fix this problem”.
Any tips on how to fix this?
Alternatively, I have uploaded my problem file here: - https://drive.google.com/file/d/1SrZwLwku2NCtx4idr6rnujnGSGkTalTf/view?usp=sharing
If someone might be so kind to have a look at it to see if it can be repaired it would be very much appreciated. I really need the audio.
I have sent you a PM with a solution to your problem.
Thanks a lot for the reply. Don’t seem to have received a PM though. Can you try to send again? Thanks
OK. Done.
Thanks so much for your kind help!
You are welcome - glad you got it sorted. :smiley:
Hey all,
I have found this forum after finding myself in the nightmare scenario. I had about 30 minutes of audio spliced together, and it crashed while recording. I ran the tool twice, and got the same error.
If someone could help me figure out what is going on, I would be so grateful. After running the program, I just get the same error: Cannot read from D. It is a 50gb file, and the program runs for about 5 minutes before stopping.
If anyone can help, I will be so grateful.
So that is a big file. I would take a look at the file but how would you get it to me? And how would I get it back to you?
Perhaps you can copy the entire “cmd” output screen, paste it to a text file, then post that.
Do you have sufficient free space on your machine? And don’t try this using a network’d drive.
Thanks for the word. :smiley: :smiley: :smiley:
does anyone know where the exe files are, Ive downloaded the tool but not a single exe file is in there.
Did you download "audacity-project-tools-1.0.0-win64.zip " from Release 1.0.1 · audacity/audacity-project-tools · GitHub ?
The zip file contains audacity-project-tools.exe and sqlite3.exe nestled neatly inside of a audacity-project-tools-1.0.0-win64 folder.
You many need to go to Windows File Explorer > View Tabs > and Check the “File Name Extensions” box to see the .exe file extensions.
