Sorry, I did not give the info necessary. I would like to convert WMA files to WAV. Just started on Audacity 2.0.5. and using Windows 8. After editing, will use Adobe’s Premier Elements. Again, thanks !!
Is this part of an earlier post? I didn’t see anything associated with you. Koz
WMA will apparently open up in Audacity with the FFmpeg libraries installed. After the work opens, File > Export: WAV (Microsoft).
Download FFmpeg here http://manual.audacityteam.org/o/man/faq_installation_and_plug_ins.html#ffdown .
thanks, Koz. However, I don’t understand. Could you bring your information down to the basics, please.
-Dave
Please avoid double posting.
There are other answers in your duplicate post here: https://forum.audacityteam.org/t/wma-file-does-not-import-solved/32188/1
I’ll lock this topic to avoid confusion.
