Correcting Acoustics for "Tin- can Effect"
Audacity 2.4.2 Windows 10 64
I have learned my way through about 40 LP transfers. Wow what a program!
One problem i haven’t been able to fix is the reverberation on some European recordings by Everest/Cetra from the 1950s. Reverb may be a bad description. It sounds like the recording may have been made in a theater or a large studio with no means of damping the sound. It is worse when only one person is singing and is not too bad when the orchestra is playing or a group are singing.
My description may be too nebulous to tell what it going on or the problem may not be fixable. Thank you for any help
There are de-reverb plugins … https://forum.audacityteam.org/t/remove-room-noise-from-poorly-recorded-speeches/54578/2
but IMO the artefacts they create would ruin a musical performance: more harm than good.
Thank you!
