hi
I want to use audacity for copying non commercial cds…how can I do that with audacity??I TRIED TO DO THAT BUT IT SEEMS TO BE COMPLICATED…
LENNY
hi
LENNY
It does, yes. There is no “copy CD” unless you have a stand-alone player which can do that. The process is to “rip” the show from the original CD and burn it onto a new blank CD. Two separate steps. Audacity won’t do any of those things. Audacity can edit and change the show between the two steps, but it won’t rip or burn.
Thanks
I use [u]EAC[/u] for ripping (creating WAV files from an audio CD) and I use [u]ImgBurn[/u] for burning.
But, Windows Media Player or iTunes can probably handle both tasks.
