Hello,
I have tried to find the answer in this forum but nothing …
So, my problem is, i try to export an audio record (recorded with iphone) to this :
PCM .wav mono 16 bits – 8KHz – Taille maxi 2 M
I have found the solution for PCM, WAV, 16 bits but not for 8Khz.
When i change the rates to 8khz, the voice is completely low.
How to conserve the audio and changing the rate at the same time ?
Thank you very much… i’m using Audacity 2.1.2
Rolax
