I know this has been talked about before but I couldn’t find any recent info.
Can I reduce the monitor volume (i.e. the sound I hear during recording) independent of system volume? I can’t find a way of doing it.
I have Blackhole, Background Music installed and am happy to use them to get where I want to be.
Thanks
odododododod
Mac M1 RAM 16GB running MacOS v 12.6 Audacity 3.2.1
Should I already know the answer to this?
Help anyone?
November 9, 2022, 11:07am
3
Why not use “system volume”?
I’d like to be able to turn down the volume on Audacity independent of the system volume, so that while I’m ripping an LP I can check the recording then listen to something else.
The BackgroundMusic App (https://github.com/kyleneideck/BackgroundMusic ) can control other apps but for some reason not Audacity, otherwise I’d do it that way.
Thanks
My mistake. If I route Audacity into Background music, I can raise and lower the volume!
It would be nice to be able to do this with just Audacity, but at least I can get the result I want.
