Another annoying and time wasting glitch is driving me crazy! Even ChatGPT gave up on me! Problem: During editing of my 2-person podcast show when I need to silence one clip (not the other), I highlight what I want silenced a zillion times before (I’ve released 350 shows in the past 6 yrs.), I tap control L and Audacity injects the silence okay, but creates a split at the beginning and end of the silence clip. To rid the splits and join the clips, I’ve tried using control J To join the clips. The problem with this work around is that Audacity takes forever to execute the join. If that doesn’t take a huge amount of time to fix for a one hour show, nothing will. I’ve tried all of standard work around including closing Audacity, restarting, pulling tracks from problem track and trying them another project etc All to no effective. I tried loading Audacity and replicating the problem and it seemed to work OK. The problem is that I decided to unload 4.0 and reinstall 3.7.9 Because of other glitches that I don’t have time to work on myself in the midst of a looming deadlines for the podcast . I’ve been using Audacity for the past 7 or 8 years and have put up with The good and bad that people discuss in the forum. It’s been helpful and valuable to read everyone’s feedback and it saved me a lot of time over the years. But this current problem is sufficiently frustrating, and I haven’t found any answer to it elsewhere, That I am hoping one of the res geniuses can offer so meaningful ideas for resolution. Thanks to all! P.S. In looking at one of the similar topics, my problem is different then eliminating silence at the end or beginning of tracks. I’ve done that plenty of times before, but my issue deals with trying to affect a silence and having two splits occur as a result of that Control L action.
That seems to imply that the problem is with that one specific project, and the tracks within that project. When you try to reproduce the problem in a brand new project the problem does not appear. Right?
My suggestion is to export the individual tracks from the problem project as WAV files then import them into a new, clean project.
