Hi,
i wanted to connect Files in a Folder to one single File.
Is there a way I can do this with macros?
Thanks in Advance.
Best Regards
Richard
Hi,
Thanks in Advance.
Best Regards
Richard
So you could do File>Import and select all the files you are interested in. (For your first test just choose a small subset).
This will load all of your files onto separate tracks in Audacity.
Then Tracks > Align Tracks > Align End to End. This will push later tracks to start at the end of the prior track.
Then File > Export Audio > Export Range > Entire Project.
