Hi all
Recent (Yesterday!) convert to Windows 11 here, after a hard drive failed!
I downloaded Audacity 3.7.7, and now I have to manually reset the height each time I use it! Shift-CTRL-F works but only for that session.
I looked for the config file, but there isn’t one!
Please, can someone help?
Many thanks!
Where did you look for it? It should be somewhere in a subfoler of %appdata%, in a folder named “audacity” (all lowercase letters).
Since I am not using Windows, I cannot tell you the exact subfolder name/path now.
Trebor
3
Thank you Romontschun! I found it! I was looking in the wrong place!
Thank you Trebor! I found the little blighter hiding in plain sight!
system
Closed
6
