Using Audacity 3.7.1 I am trying to record my Genos but all connections are as advised but nothing is recording I am still using Windows 7 could this be the cause?
And how is that? How is it connected?
Audacity can record (digitize) the ANALOG audio IF you have a computer with a regular soundcard with a line input (blue) or if you have a USB audio interface with line inputs.
The microphone input on a laptop (or soundcard) is “wrong” for line-level or headphone-level signals.
Audacity is not a MIDI application and it cannot capture/record MIDI messages. (I has some VERY limited MIDI functions.)
Or, if you are running a MIDI application and you are getting the sound out of your computer speakers, you can Use WASAPI loopback to record the sound coming OUT of your soundcard.
…From what I could find, the USB connection on your keyboard is MIDI only… No regular digital audio.
