Sorry, Miguel, but I did not recall that you were visually impaired. I was only thinking of the fact that recent Audacity could recognise the waveshell
files properly.
Don’t worry, I guess that’s normal because I’m not an often poster, since I try to know some things by asking ere or reading in the existing posts. It’s normal don’t know or recall some things about anyone, although I’m surprised 'cause you know my real name.
files properly.
Well, it can. Even it loads the mono versions of all the plugins; at the beginning I thought it was going to crash but it didn’t happen
. I am able to see the compresors, limiters, the equalicers etc, but with this phenomenon which I have explained above.
If your screen reader says there is a Preview button, either you are not using the current Audacity 2.1.1 which has
real-time preview of VST effects, or there is a fault in your screen reader.
In fact, I have named it like “preview button” because I don’t know how to say it in english, since as you can see, I’m not a native english speaker. I’m using the version 2.1.1 because it also has the vocal remove/extract effect. And yes, when you click in the start playback button (sorry if I have translated it wrong) it’s possible to change the settings in the current effect, such as the volume parameters in the limiter or the OmnyVerb controls. But regarding to Waves plugins, I am unable to use them with the graphical interface enabled or without it. When I move the sliders, the incoming sound is procesed with the default options; I tested it using the Enigma effect. I can’t know what happens with the graphical interface, so maybe they could work with it.
Really this is not the best place to get help with VI issues. Robert J. H. who contributes much to Audacity Forum is visually impaired, but if you use the Audacity4blind mailing list, everyone there will automatically know you are visually impaired.
Anyway I only meant my screen reader in case of doubt, since I’m a blind person, and sometimes I can’t see literally what is on the screen. So I thought maybe you could use the effects or see something. I’ll check that list, and although I am not used to employ them, I’d be interesting to take a look.
Have Waves confirmed whatever compressor you are using is fully accessible?
No, they haven’t. However, I have used allmost all the waves effects in different sound editors with my screen reader, so it’s a bit strange that this is not like that in Audacity.
Ah, another thing: I alwais come here for help, because basically this team is who develops Audacity, and so it’s good to get answers from the people who knows the manner of how it works.
Best regards, and thanks!
