first thing i wanted to do was start editing on the newer computer.
so i downloaded the current version of audacity. and when it did not recognize my m4a file, i was able to follow instructions, and download the ffmpeg (sp?) system. and now it opens my file
my computer and audacity version was probably 10 years ago or so
my latest project is going thru all my files and compressing them. this is so i can get a more equalized volume. as most of you probably know, any sort of amplification of the files always looks at all the peaks, and then amplifies only to the point that nothing goes past a certain point.
that is the weakness. if you have a music file with a few peaks in them (which is most common), the rest of the file will be curtailed. what compressing the file did, was to raise the rest of the wave form, such that the peaks were minimal, and then the whole file could be amplified, giving on average a music file that would play twice as loud
with this new version of audacity, however, the waveform only gets smaller, and it does not really end up removing the peaks. because if you amplify it again, the peaks are back to where they were before.
on the old computer, i always used the standard compress settings. and i did the same with this new version. although i think the questions are all different. in any case, i would have expected the standard settings to work basically the same. they are almost 180 degrees out of phase - LOL. since i dont know anything about the settings, i left them alone. as it basically did the job i wanted.
the old way was much better. cuz i could just continue to compress until such a point, where there were no significant peaks. i mean sometimes you can get a monster peak from the artist making one loud note.
any clues on how i can make this new audacity work more like the old one ? on the new one, threshhold = -10, make-up gain = 0, knee width = 5, ratio = 10, look a head = 1, attack = 30, release = 150
