Compiling Audacity 4 on Linux (Ubuntu 24.0.3) Fails
I posted on this Discord, crossposting here.
I was interested in maybe contributing to Audacity 4 or just dabbling with it. I have run into an error when trying to build however. It’s been a little painful trying to get it all running, I am wondering what I am doing wrong–probably something stupid.
I know in BUILDING.md it says to add all the relevant tools to PATH, but I wasn’t quite sure what to put? I configured the CMakeCache to use Ninja and Qt, as far as I can tell, but I am running into issues. I compiled my process here:
https://docs.google.com/document/d/1TYsAQmlX61o2xFBe02UInIVvW-O4novH1qsUKyk8mEc/edit?usp=sharing
TLDR: Need ALSA? But it can’t find it. When I force it to, then I have a new issue.
My main issue is having to do with installing a lot of dependencies to get this working, which makes me think I need to modify my PATH. Not sure exactly what to update it to though?
Hey it’s working now, I talked with user copicraft on Discord.
Here’s everything I did to get my build working:
I needed to install:
libgl1-mesa-dev
libasound2-dev
gtk2.0
and removed
PRIVATE Qt${Qt_VERSION_MAJOR}::GuiPrivate
from line 298 in
/home/twerp/repos/audacity/muse_framework/framework/dockwindow/thirdparty/KDDockWidgets/src/CMakeLists.txt
Ope wait never mind, removing that from the CMake broke KDDockWidget
Current issue:
general_messages.txt (12.3 KB)
Bumping this since I am still having the issue
This is unresolved if anyone knows anything. Removing GuiPrivate results in a build failure, but allows the CMake to generate.
Resolved the build issue.
Ninja just didn’t install the deps. The CMake error was making it out to be a bigger problem than it was. Was missing another dep. Ran source your/directory/for/audacity/buildscripts/ci/linux/setup.sh and this fixed the CMake error and the build error.
Have a new error on runtime where it doesn’t seem to actually run? I’ll update with more info.
