Hello,
I am wondering if Audcacity is compatible with the following interface: Behringer Guitar Link UCG102. I have purchased this, and although, it comes with software, I’m wondering if Audacity is compatible. Thanks
Hello,
Since you already have one, plug it into the computer, let Windows chew on it for a while and see if it appears – to Windows. Leave Audacity closed.
Go into Windows Control Panels > Sound and see if the USB device appears. IF it doesn’t, then you may need the additional drive software. Audacity can’t see anything Windows can’t see.
Once Windows is happy, then launch Audacity and find the device using the device toolbar.
http://manual.audacityteam.org/o/man/device_toolbar.html
It would be very surprising if it isn’t as Behringer include Audacity in their software bundle.
