Help please. I want to record something from the radio playing on my laptop, onto audacity on my laptop. And it isn’t working. I have used Audacity before on previous computers, and it has worked fine.
I am using Audacity.2.1.3. I honestly cannot remember if I obtained the zip or not, but I think (65% sure) it was the exe installer.
I have a Lenovo ideapad running windows 10 Home which has a combined headphone and mic jack (3.5). I bought a StarTech IC USB which should mean I can plug a lead into the 2 sockets on that and record something playing on my laptop onto audacity using a lead plugged into both holes on the StarTech. But it won’t work. I have a lot of static noise (see screen shot below) but it is not recording. If I plug headphones into the StarTech then I hear the sound playing ok (through the hole at the back!), if I plug my ipad in and play something from that then that records ok (through the hole in the front). But if I put a lead from the back hole to the front hole, on the StarTech, and play something then I get a flatline on the audacity. Audio device info is all below.
Default recording device number: 1
Default playback device number: 4
Device ID: 0
Device name: Microsoft Sound Mapper - Input
Host name: MME
Recording channels: 2
Playback channels: 0
Low Recording Latency: 0.090000
Low Playback Latency: 0.090000
High Recording Latency: 0.180000
High Playback Latency: 0.180000
Supported Rates:
Device ID: 1
Device name: Microphone (USB PnP Sound Devic
Host name: MME
Supported Rates:
Device ID: 2
Device name: Microphone Array (Realtek High
Host name: MME
Supported Rates:
Device ID: 3
Device name: Microsoft Sound Mapper - Output
Host name: MME
Recording channels: 0
Playback channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Device ID: 4
Device name: Speakers (USB PnP Sound Device)
Host name: MME
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Device ID: 5
Device name: Speakers (Realtek High Definiti
Host name: MME
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Device ID: 6
Device name: Primary Sound Capture Driver
Host name: Windows DirectSound
Low Recording Latency: 0.120000
Low Playback Latency: 0.000000
High Recording Latency: 0.240000
High Playback Latency: 0.000000
Supported Rates:
Device ID: 7
Device name: Microphone (USB PnP Sound Device)
Supported Rates:
Device ID: 8
Device name: Microphone Array (Realtek High Definition Audio)
Supported Rates:
Device ID: 9
Device name: Primary Sound Driver
Low Recording Latency: 0.000000
Low Playback Latency: 0.120000
High Recording Latency: 0.000000
High Playback Latency: 0.240000
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Device ID: 10
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Device ID: 11
Device name: Speakers (Realtek High Definition Audio)
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Device ID: 12
Host name: Windows WASAPI
Low Playback Latency: 0.003000
High Playback Latency: 0.010000
Supported Rates:
48000
Device ID: 13
Device name: Speakers (USB PnP Sound Device) (loopback)
Low Recording Latency: 0.003000
High Recording Latency: 0.010000
Supported Rates:
Device ID: 14
Supported Rates:
48000
Device ID: 15
Device name: Speakers (Realtek High Definition Audio) (loopback)
Supported Rates:
Device ID: 16
Recording channels: 1
Supported Rates:
Device ID: 17
Supported Rates:
Selected recording device: 2 - Microphone Array (Realtek High
Selected playback device: 5 - Speakers (Realtek High Definiti
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Available mixers:
Available recording sources:
0 - Master
Available playback volumes:
0 - PCM
Recording volume is native
Playback volume is native
