Hi,
Currently getting to grips with the new version. When I record a stereo track, great no probs. But if I set up a click track silence…I hear nothing.
Mess around with some settings and when I go to record, a red line and arrow appear at the start of the new track and nothing
I bet I just need to adjust something…where would be good place to start ?
Windows 10 & a Presonus audio box USB.
And timeline look like this when you get done?
Where do we lose it? The click track settings I believe are default. I’ve never used it, so I think those are the factory settings.
Narrowed the problem down, if I select the computer speakers it records fine. If I select the audiobox to monitor the track it doesn’t record.
Strange, any ideas ?
Please describe, step by step, what you are going, and what the problem is. Imagine that we can’t see your computer (we can’t) and walk us through reproducing the problem.
