Changing the songs title to match the MP3 name
In the old version I could change the song title of the mp3 to match the name. I can’t figure out how to do that in the new version.
In the current version there is an Edit Metadata button in the lower-left of the Export Audio menu.
If you just want to edit tags/metadata without editing the audio, Mp3Tag is free and it works will all of the popular audio formats, not just MP3. It’s handy and it only “touches” the metadata. (Or there are other similar tagging applications.)
Audacity has to re-write the whole file, and if you are editing an existing MP3 you are going-through another generation of lossy compression. And, Audacity doesn’t support embedded artwork.
Thank you this solves my issue. I’m not doing anything fancy so it all works out.
